Stage 2 with Tiptronic
Results 1 to 19 of 19
Thread: Stage 2 with Tiptronic
    VDubber
    Dec 2009
    Harrisburg PA
    80
    Question Stage 2 with Tiptronic
    So I'm planning on going stage 2 on my car and I read online that some automatic transmissions can't handle the power and don't shift quick enough. Has anyone gone stage 2 on a tiptronic car or would I have to change to a manual? Because I'm pretty sure if I found another mkiv that was manual I could just rip out the transmission and shifter..right?
    Moderator-ing cbursten's Avatar
    Dec 2007
    United States
    3,622
    Default Re: Stage 2 with Tiptronic
    Add a clutch pedal, clutch cylinder, slave cylinder......................
    I would re-think that plan. Consider starting over with a different car. You'll really end up spending a lot more than it's worth.
    Hidden Content Originally Posted by shaun07 Hidden Content
    i just take it off, and ****ing drink it like a ****ing man. see these ****ing balls? see these pecs? see this dixck? i piss 103 octane 6 days a week, and pure awesomeness on sundays
    That's how I R๖hrl kootenaydub's Avatar
    Apr 2009
    BC, Canada
    3,084
    A mkiv auto should be able to handle stg 2 no problem, or am I totally wrong here.
    '08 BMP 4dr DSG - Stage 2 - powered by element 105
    ( (•)O==(\X/)==O(•) )
  5. Remove Advertisements
  6. #4
    GTI Master hambone64's Avatar
    Mar 2009
    San Jose, CA
    1,874
    Quote Originally Posted by kootenaydub View Post
    no i think your right... but then again i might be completely wrong too
  7. #5
    Dec 2007
    United States
    3,622
    I think it can handle the power in the short run (and maybe the long run), but the performance will not be on par with a manual car. But if you don't have any other options, go for it. I wouldn't attemp a tranny swap, though.
  8. #6
    Apr 2009
    BC, Canada
    3,084
    Quote Originally Posted by cbursten View Post
    x2 on the tranny swap, get a diff car instead
  9. #7
    REVIEW STAFF
    boostedJTi's Avatar
    Jul 2007
    Florida
    27
    12,562
    Actually, tranny swap isn't that hard. I did an 02m swap on an auto jetta...
    You need a tranny, the associated hardware (i.e. the hydraulic shift lines, the shift tower, the shifter, the pedal set, etc.)
    Vwvortex probably has a write up on how to do it. It is fairly simple. But I would HIGHLY recommend getting the proper star bits for the job...
    02 GTi - Totaled
    98 Golf 4 door - Sold
    93 Corrado SLC - Sold
    00 Passat GLS - DD
    13 Golf - DD
  10. #8
    Brings The Ruckus D.Light's Avatar
    Jan 2008
    407
    6,854
    No the trans swap sucks you have to re wire electronics re-route coolant hoses, ground out reverse lights, major pain in the ass, no a tip can't hold the power, yes you're better of getting a dif car and no vortex doesn't have a diy /thread
    VTAkkiiiin
  11. #9
    REVIEW STAFF
    boostedJTi's Avatar
    Jul 2007
    Florida
    27
    12,562
    Quote Originally Posted by D.Light View Post
    Rewiring a neutral safety switch... That's hard. Coolant hoses are hard too? Just go buy about 2' of hose from the store and you can make your own coolant hoses. That takes a good 3 hours... Reverse lights are actually already in the system so you simply have to wire them to the sensor on the tranny...
    A tranny swap is cheaper than getting another car. But it is possible and not as difficult as it is made out to be. Or maybe the fact I have done a few of these helps me.
    02 GTi - Totaled
    00 Passat GLS - DD
    13 Golf - DD
  12. #10
    Jan 2008
    407
    6,854
    I've done it to and it isn't easy by any means, and if you want rev lights to work you have to have parts of the wiring harness from a man.
    VTAkkiiiin
  13. #11
    VDubber
    Dec 2009
    Harrisburg PA
    80
    Thanks for all the input. I might try the tranny swap or get all the pieces and pay someone to do it. Would my car be lighter with a manual tranny? Or not enough for it to matter?
    And you guys seem to know everything...
  14. #12
    Mar 2009
    San Jose, CA
    1,874
    Quote Originally Posted by 02GTIboy View Post
    thats kuz we do
  15. #13
    REVIEW STAFF
    boostedJTi's Avatar
    Jul 2007
    Florida
    27
    12,562
    Quote Originally Posted by hambone64 View Post
    thats kuz we do
    That's caus Dlight myself and Shelby do... lol
    02 GTi - Totaled
    00 Passat GLS - DD
    13 Golf - DD
  16. #14
    Dubster 1FastGTI's Avatar
    Sep 2009
    Bronx, New York
    111
    Actually having auto with stage 2 is a death sentence 4 months and a non shifting tranny to prove
  17. #15
    Jan 2008
    407
    6,854
    It depends how good you are under the hood, and weight dif is nominal, you'll get more power to the wheels for sure though
    VTAkkiiiin
  18. #16
    Dubber In Training
    Nov 2009
    17
    Damn that blows!!..
    I too have tiptronic.. that just killed my desire
    to work on my car.. danngg...
    Anyone kno if theres a good swap kit for a 03 gti 1.8t..
    ima have to hold off on that st2 chip.. ..
    Dam.. i was so close too..
    I've been noticing super delayed shifting on tip too..
    like almost 1000 rpm delay..
  19. #17
    Sep 2009
    Bronx, New York
    111
    Cool Re: Stage 2 with Tiptronic
    yea I bought the car Stage 2 chipped and when I first drove it had a slight delay of 1000 rpm. After 4 months every week a gear went and now the car has to be completely warm for second gear to shift 3,4,5 don't shift its like the car is in neutral. It blows but I got an estimate from a guy he would do a tranny swap for $1000, but I don't know if hes gonna do everything. When the switch is done I plan on going stage 3 Uni or Revo like the big turbo options.
  20. #18
    Dubster jaybru's Avatar
    Jul 2010
    Chicago , IL
    25
    169
    *bump*
    so is it still unknown if it can handle stg2 ?
    do any of you own a tip with stg1 ?
  21. #19
    Mar 2008
    Bronx, NY & Allentown, PA
    31
    15,540
    should be fine IMO
    14 S4 & 03 GTI 1.8T & 04 Golf
    96 GTI 2.0 (Sold)
    00 Passat Wagon 1.8T (Sold)
    Hidden Content
  1. Tiptronic problems
    By puckdud in forum MKIV GTI
    Last Post: 05-02-2009, 07:19 PM
  2. Definition of Stage 1 or Stage 2
    By vnkn23 in forum 2.0T FSI / TSI Engines
    Last Post: 03-04-2009, 06:22 AM
  3. Tiptronic from any mode??
    By Fahrenheit_618 in forum VW GTI Problems / Complaints
    Last Post: 12-29-2007, 09:30 PM
  4. MANUAL VS AUTO-Tiptronic
    By Revoluxion in forum MKV GTI
    Last Post: 09-25-2007, 12:36 AM
  5. Tiptronic upshifts by its self?
    By GTI guy in forum PERFORMANCE DRIVING
    Last Post: 09-02-2007, 10:37 AM
