AirBag Fault Code 00589
Results 1 to 27 of 27
Thread: AirBag Fault Code 00589
    GTI Master Red_MK4's Avatar
    Jun 2009
    Right now at Pittsburg, KS.... Permanent Home at Miami, FL
    27
    912
    Default AirBag Fault Code 00589
    I'm having the following problem with my mkiv. I got my gti just a few weeks ago and I bought with the airbags light on. I took it to a mechanic and the code reads the following,
    00589 - Airbag Igniter; Passenger Side (N131): Resistance too High
    Any ideas on how to fix this? I think I may need to replace the passenger's airbag to fix this.... or not??
    Any ideas, has this ever happened to anybody?
    HELP WOULD BE GREATLY APPRECIATED...
    Mar 2008
    Bronx, NY & Allentown, PA
    32
    15,542
    Default Re: AirBag Fault Code 00589
    did you reset the code?
    i got that code about 5 months ago erased it with vag com and it never came back.
    14 S4 & 03 GTI 1.8T & 04 Golf
    96 GTI 2.0 (Sold)
    00 Passat Wagon 1.8T (Sold)
    Hidden Content
    Mar 2008
    32
    15,542
    this was the code i got
    VAG-COM Version: Release 409.1-US
    Control Module Part Number: 1C0 909 605 F
    Component and/or Version: 08 AIRBAG VW61 0202 0001
    Software Coding: 12344
    Work Shop Code: WSC 00000
    1 Fault Found:
    01218 - Side Airbag Igniter: Passenger Side (N200)
    32-10 - Resistance too High - Intermittent
    96 GTI 2.0 (Sold)
    Hidden Content
  5. Remove Advertisements
  6. #4
    Mar 2008
    32
    15,542
    Quote Originally Posted by SMS LLC. View Post
    OH BTW the passenger seat side air bag needs to be replaced.... But just clear the code you probably wont see it again
    thats what sms told me, and he was right. light has not come back on since. (knock on wood)
    he is a certified VW tech and has his own parts business. check his site out.
    give him a call if you like, he is very helpful
    96 GTI 2.0 (Sold)
    Hidden Content
  7. #5
    Jun 2009
    27
    912
    I did reset the code twice already with no luck. I guess I'm gonna have to check the wiring of the airbag and hopefully it's just that... I don't wanna replace the airbag because that's too expensive lol....
  8. #6
    Mar 2008
    32
    15,542
    you dont sit in the passenger side lol
    96 GTI 2.0 (Sold)
    Hidden Content
  9. #7
    Dubber In Training
    Jul 2009
    San Francisco,California
    18
    Smile Re: AirBag Fault Code 00589
    Quote Originally Posted by Red_MK4 View Post
    I have also reset the code twice & i also no luck.
    Got a new Hidden Content Kit for my R32.
    Hidden Content
  10. #8
    GTI Master Roflsaurusrex's Avatar
    Oct 2008
    southern ct
    31
    899
    be careful with that because the airbag can blow up in yo face.
    For sale: 2005 1.8T GTI - Unitronic Stage 2 w/ SAI delete; Forge TIP; 3" IC Piping to Godspeed FMIC; Forge 007; SAI Delete; Catch Can; Spec Stage 2+ Clutch w/ 14lb Fly wheel; Raxles; KW Variant 1 Coilovers; BFI Stage 1 motor mounts; R32 control arm bushings; Neuspeed Front (25mm) & Rear (28mm) Sway Bars
    Hidden Content
  11. #9
    My Fast GTI Official Sponsor
    Feb 2008
    691
    Quote Originally Posted by Roflsaurusrex View Post
    Never seen that happen!
    If its a hard fault (meaning it wont go away) then the unit needs to be replaced. I can get the airbag units for you guys but I will need your VIN. Plus if the air bag light is on, it means that your airbag system is completely disabled. (IE) If you get in an accident then it will not deploy anything!
    Authorized UNITRONIC Dealer, BSH Dealer, EUROJET DEALER, ATP TURBO DEALER, Integrated Engineering Dealer, 42DD Dealer and ABD Dealer, VW/Audi Tuner, Hidden Content
    FEATURED PRODUCTS: MKV FMIC STARTING @ $625.00 AND ALUMINUM VALVE COVERS / MKIV BIG TURBO KITS STARTING @ $2999.99
  12. #10
    Jun 2009
    27
    912
    this is what i'm going to do... I'm gonna disconect the battery, then open up the glove compartment and take a look at the airbag wiring and the airbag itself, then go to my friends shop and erase the code and see what happens, if no luck. I'll let you know my vin #. Thanks...
  13. #11
    Oct 2008
    southern ct
    31
    899
    Until one day you're workin on something and BOOM. then you get an upclose experience
    Hidden Content
  14. #12
    Dubber In Training
    Jan 2009
    5
    Hey,
    I have the same problem as you... did you get it resolved? Are you sure it's the wiring to the dash-bag and not the airbag in the seat?
  15. #13
    Jun 2009
    27
    912
    Today I removed the glove box and I saw the wiring and they look normal with the exception of one cable that was unplugged.... Look at the pics and tell me what do you think? If the problem is just that unplugged cable then AWESOME! but if it's not that do I need to change the whole airbag?
    thanks
    I haz heated seats for Miami Florida! Hidden Content
    --- Full APR Stage II, Forge 007, SouthBend Stage 2 Clutch with 13 pound Flywheel, EVOMS V-Flow, ECS Light Weight Pulley Kit, ECS Dogbone mount insert, ECS Race Valve, Forge TIP, MK4 Full TurboPod w/ Indigo Boost Gauge, Greddy Turbo Timer with Companion Lite, Pioneer F90bt with Kicker Sub, TR Eyelids, 15% Tinted Windows, debadged, blacked out VW emblem, grill, side lights, and rims ---
  16. #14
    Jun 2009
    27
    912
  17. #15
    Jun 2009
    27
    912
    Ohhh... You can click in the pic for hi-def pics :d
  18. #16
    Jun 2009
    27
    912
    Quote Originally Posted by bobostunk View Post
    Hey,
    depends on what's your fault code though.... mine's 00589 that says is the passenger airbag, i think the 00588 is the one for the passenger side airbag seat though, but i'm not sure....
  19. #17
    Jun 2009
    27
    912
    OHH.. about the unplugged cable.... I think that's just the cable for my glove compartment light right?
  20. #18
    Dubber In Training
    Jan 2009
    5
    Red face Re: AirBag Fault Code 00589
    Hey,
    i tried clearing my code and it didnt go away.
    I've been looking around and yeah, that loose cable is the one for your glove-light. i have the exact same error code as you. i unplugged the battery and disconnected the yellow connector... hoping to find corrosion or something. but it looked pretty good.
    hooked everything back up and am going to try and clear the code again next week.
    but im basically at the same point you are right now. i'll let you know what ends up happening... post up any advances please.
  21. #19
    Jun 2009
    27
    912
    Hey,
    Ok. I will, and the same goes for you! keep me updated... good luck...
  22. #20
    Jun 2009
    27
    912
    Well, I finally fixed it!!!!! I bought an used airbag from a 2004 Jetta from Ebay for 80 bucks, installed it myself and then took it to my shop to reset the fault code for free and it didn't turn back on!!!! so I fixed it for only 80 bucks!!! amazing!!!! and the dealership wanted me to charge me 400 bucks for the airbag plus labor.... WOW!!! lol I'M SO HAPPY!!!! :d
  23. #21
    Oct 2008
    southern ct
    31
    899
    Until one day you're driving along and BOOM.
    Your airbag goes off but that d-bag friend of yours has a face full of windshield!
    GREAT SUCCESS!
    Hidden Content
  24. #22
    Jun 2009
    27
    912
    GREAT SUCCESS!
    the airbag came from a vw jetta though so it's working properly with no problems whatsoever....
  25. #23
    Oct 2008
    southern ct
    31
    899
    Quote Originally Posted by red_mk4 View Post
    the airbag came from a vw jetta though so it's working properly with no problems whatsoever.... :d
    boom!
    Great success!
    Hidden Content
  26. #24
    Dubber In Training
    Jan 2009
    5
    Congrats man,
    I am still trying to troubleshoot mine. but I'll probly end up going the way you went if I can't fix it in the next week. no way in hell im payin 400 bucks for an airbag i dont plan on using.
  27. #25
    Jun 2009
    27
    912
    Congrats man,
    "i don't plan on using it. lol" what fault codes do you have? maybe i can help you out.
  28. #26
    Dubber In Training
    Jan 2009
    5
    I had the same fault you had... 00589...
    Just rescanned it thoough and now, in addition to that, i have a wonderful 65535 Internal control module memory error....
    wonderful.... anyone know where the airbag control module is?
  29. #27
    New Dub Cub
    Jan 2014
    Sydney Australia
    2
    Hi RED MK4
    How did the 00589 error finish off, My MK5 has the same issue 00589-Over Limit on the passenger side...
    Any advice would be appreciated....The local lads tell me it is $150 AUD Diagnostic + Labor $95.00 and parts
    They cannot give me a set approx hours for repair.
    Thanks in advance
    C
  1. Oil Pressure fault
    By FoxieRoxie'sGti in forum VW GTI Problems / Complaints
    Last Post: 10-01-2010, 01:07 PM
  2. AIR BAG FAULT LIGHT
    By GTI Thumper in forum MKV GTI
    Last Post: 02-11-2009, 06:05 PM
  3. Air Bag Fault
    By Vdubdriver in forum VW GTI Problems / Complaints
    Last Post: 11-10-2008, 03:58 PM
  4. Airbag light on?
    By nukinfutz in forum MKIV GTI
    Last Post: 10-11-2008, 12:58 AM
  5. Airbag
    By Dacarde01 in forum VW GTI Problems / Complaints
    Last Post: 10-09-2007, 09:53 PM
