Replacement Batery
Results 1 to 5 of 5
Thread: Replacement Batery
    Dubber In Training KBoltz's Avatar
    Feb 2017
    5
    Default Replacement Batery
    Anyone go with the 35 series Optima Red Top?
    The battery did NOT want to start the car this morning. It was 15 degrees this morning and it was like, click. Finally, I shut down everything, and then it kicked it over and started right up.
    O'Reilly's has an AGM battery for 169 bucks. I might just go with that since they have it in stock.
    Or, I wonder if I just put it on my battery tender that I use for the Corvette, if that would help for a couple of days.
    DAS IST MEIN FAST
    fastgti's Avatar
    Apr 2007
    AUGUSTA, GEORGIA
    36
    5,855
    Default Re: Replacement Batery
    Always try the battery tender first before buying a new one
    Hidden Content 2007 VW GTI APR STAGE(DYNOED AT 450CHP ON 95 OCT; 2005 AUDI S4 (sold); 2012 VW JETTA (sold)1965 FORD GALAXIE 500 XL CONVERTABLE 4 ON THE FLOOR, 390 CUBIC INCH MOTOR, DODGE VIPER RED; 2013 Chevy traverse 2LT.
    Feb 2017
    5
    Charged it last night, not a click or anything this morning.
    Time to buy a new battery.
  5. Remove Advertisements
  6. #4
    DAS IST MEIN FAST
    fastgti's Avatar
    Apr 2007
    AUGUSTA, GEORGIA
    36
    5,855
    Yep. I am running an Interstate battery. Nothing special about it
  7. #5
    Feb 2017
    5
    Default
    Replaced the battery and still wouldn't start this morning. Did some reading and seems this is the cold start issue that a fair number of people have had. Either ignition switch, both electronic and mechanical, seems to be the culprit for most plagued by this. We are moving to a warmer part of the country in April anyways. Until then I am going to be a small ceramic space heater in the car and turn it on when I get up in the morning.
    With the heater (has an anti tip device) on low overnight, it started just fine this morning.
  1. replacement valve?
    By mk5fastgti in forum VW GTI
    Last Post: 08-12-2013, 02:21 PM
  2. Replacement Key?
    By Armn in forum VW GTI
    Last Post: 12-29-2012, 01:11 PM
  3. replacement key
    By dtrain36 in forum MKIV GTI
    Last Post: 12-12-2012, 08:59 AM
  4. Radiator replacement help
    By wkoslo in forum MKV GTI
    Last Post: 01-04-2012, 07:37 AM
  5. Replacement Tires
    By Gunny in forum VW GTI SUSPENSION
    Last Post: 02-19-2007, 11:51 PM
