windshield wiper streaking
Closed Thread
Results 1 to 23 of 23
Thread: windshield wiper streaking
    Default windshield wiper streaking
    I just got a brand new 2008 black GTI and I love it, except for one little annoying problem. The driver side windshield wiper streaks. More specifically it "bridges" or does not make complete contact with the glass. It leaves about a 3" swath that just happens to be in my line of sight. It's actually dangerous because it creates a big blind spot right in front of me. Now it gets weird. I took it in to the dealer and they replaced it with out any questions but the new one does the exact same thing. These are Bosch blades and ironically enough Bosch blades are the only ones that worked well on my old car. Any help?
    VDubber Fudsey's Avatar
    Dec 2007
    New Hampshire
    44
    Default Re: windshield wiper streaking
    Mine did the same thing for the first few times it rained I wiped them with an alcohol pad and they worked the 2nd or 3rd time after that without streaks
    I'll try that but I don't know if that will help a blade that's not quite hitting the glass. Thanks
  5. #4
    VDubber
    Dec 2007
    Houston, TX
    61
    mine does that too.. thought it was just my bad luck
  6. #5
    Dubster Lil Fussell's Avatar
    Dec 2007
    Severna Park MD
    205
    Rain-X wiper blades
    http://www.rainx.com/
    Nothing matters once that turbo spools up
    All my cares go away
  7. #6
    The two times that kind of thing happens to me is when there's a small object under the wiper, or the wiper is dirty from wiping dirty salty snow or dirty water...I usually just wipe them off with something..
    72/1200
    Inspiration begins with the turn of a key.
  8. #7
    Premium Octane bcruzin's Avatar
    Sep 2006
    Roanoke VA
    30
    1,291
    Neo-Form Blades FTW look em up.. it's all i use. 35000 miles of clear vision
    ...Semper Fi...
    \Oo) \ _w_ / (oO/
  9. #8
    Wipe 'em with alcohol like mentioned above. If that doesn't work, are you sure that the arms are angled properly? Could be bent a bit? Or try another set of different brand blades. my .02.
  10. #9
    GTI Master TwinTurboBoost's Avatar
    Nov 2007
    New York
    29
    3,275
    Quote Originally Posted by vdubber View Post
    No dont ever use alcohol on rubber!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
    You should use vinegar....little tricks
    Quote Originally Posted by slippednfelled View Post
    basically dont ever battle with TTB or Dlight, you will not win...... ever. its a rule.
    I know its off topic but its great advice.
  11. #10
    Dec 2007
    New Hampshire
    44
    Quote Originally Posted by TwinTurboBoost View Post
    Not from what I have read.....
    When wiper blades are manufactured, it is years before they are ever sold to the public. They sit in warehouses and the rubber will deteriorate over time even in the package not on your vehicle. Most wiper blades will come with an optimizer. Pretty much what this is, is a rubbing alcohol based solution on a little wet wipe. Rub that on your new wiper blade, just on the blade portion, and that will re-vitalize the blade surface, making it nice and soft so it grips your windshield and cleans it properly.
  12. #11
    I thought about experimenting with another brand but the wiper arm is unique. None of the common attachment types will fit the 08 GTI.
  13. #12
    Nov 2007
    New York
    29
    3,275
    Quote Originally Posted by Fudsey View Post
    okay have fun using cracked wiper blades, the alcohol makes rubber brittle, which over time tends to crack. I dont now what your reading but that was retarded
  14. #13
    Nov 2007
    New York
    29
    3,275
  15. #14
    Dec 2007
    New Hampshire
    44
    Is that a self portrait?
    Have you never seen the little wipe that comes with the blades??
    I have bought hundreds of wiper blades and some come with the pad and some don't....
    I wasn't being an a$$hole and there was no reason for you to be either
    Just stating something that I have always used and what some manufactures supply with their wipers.
    It removes oil, grime and diesel soot from the blades
  16. #15
    Nov 2007
    New York
    29
    3,275
    no that picture was of you, I got it off myspace.
  17. #16
    Nov 2007
    New York
    29
    3,275
    I wasn't being an a$ and there was no reason for you to be either
    I got that pic of you off myspace, and the reason why you bought hundreds of wiper blades is beacuse you used alcohol!!!!!!!!!!!!!!!!!!!!!!!! Your right it will remove oil, grime and diesel soot. It will also crack the f ing rubber over time, thats my argument kid.
  18. #17
    Dubber In Training vernon baxter's Avatar
    Feb 2008
    Houston, TX
    21
    My freaking wiper does the same thing! Wow I thought I just had a faulty blade, weird..
    '08 2 door UG GTI MkV, DSG, 18" hufs
  19. #18
    Did anyone ever solve this issue? I have another appointment to bring my R32 in for the exact same problem. This will be my 3rd trip to the dealer. My car is a whopping month and a half old and I've had the wiper arm replaced and I'm on my 3rd set of factory blades.
  20. #19
    Just in case anyone is following this thread, VW had my car for 4 days and ended up replacing the windshield. Problem solved.
  21. #20
    Hmm i just got my car monday with 23 miles on it, now has 550 on it zero windshielf wiper problems. Well good luck with that.
  22. #21
    i had the EXACT same problem... it's like a 5 inch thick block of streaking right in my line of site... very obviously a manufacturers defect.... i think i will buy the rain x....
  23. #22
    Quote Originally Posted by Lil Fussell View Post
    Rain-X wiper blades
    Worst wiper blades I ever owned. Worked great for a month or so and then they were worse than the 4 year old blades i had on the car.
  24. #23
    i just bought a pair of rain-x wiper blades after reading this forum... everyone seemed to have good things to say about them... but how the hell do i install them.... the install options given on the rain-x box don't seem to apply to the mkv since that had this little button that i pressed doen to slide them off.... any help
Closed Thread
  1. Wiper Adjustments
    By nimzie in forum VW GTI VAGCOM
    Last Post: 02-05-2009, 07:06 AM
  2. Front windshield right side wiper failure
    By Tlaren in forum VW GTI Problems / Complaints
    Last Post: 02-17-2008, 11:06 PM
  3. Wiper blade adjustment?
    By thesnowgod in forum VW GTI Newbies & FAQs
    Last Post: 02-12-2008, 07:31 PM
  4. Rear Wiper Squirter
    By Pioneer162 in forum VW GTI Problems / Complaints
    Last Post: 12-07-2007, 05:09 PM
  5. Rear wiper stopped working!
    By mikey3117 in forum VW GTI Problems / Complaints
    Last Post: 10-20-2007, 12:47 AM
