My MK4 Build Timeline Photos
Results 1 to 10 of 10
Thread: My MK4 Build Timeline Photos
    Default My MK4 Build Timeline Photos
    A 2001 GTI VR6 straight out of FL. I first bought this car back in June 2007 with a bit over 75K miles on the odometer.
    Now it has a bit over 100K so she hasn't been driven as much over the years but never neglected for one moment.
    Started off with body work preparation and fitting of the Rieger front bumper and rear bumper add on, then I was on to rebuilding the suspension and then to finalize with a very classic paint job and finish.
    This is my second MK4 VR6 as I owned a Tornado Red 2000 GTI VR6 which was painted over to Ferrari red. I bought the first one in October of 2004 and had it until June 2007 when it got totaled by an idiot who failed to give preference and was speeding.
    Luckily the MK4 is a very solid built car and it saved my life, walked away without a scratch.
    Insurance settled with me very quickly as I had already found this one 2 days after the accident and I told them that I wanted to buy it so for them to speed up the settlement process.
    As lucky as I was to find this car someone had a down payment of $500 on it and wasn't sure if it would be still within my grasp. I called the dealer and gave them my word that I'm paying for the entire car so they could go ahead and refund whoever paid down $500 on it.
    Within 29 days after my accident I received my 2001 GTI VR6 and I was happy ever since with it up to this day.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	21761 Click image for larger version.
ID:	21769 Click image for larger version.
ID:	21777 Click image for larger version.
ID:	21785 Click image for larger version.
    Check out Hidden Content for the best deals on OEM and performance parts for Volkswagen and Audi.
    Default Re: My MK4 Build Timeline Photos
    Suspension rebuild
ID:	21801 Click image for larger version.
ID:	21809 Click image for larger version.
ID:	21817 Click image for larger version.
ID:	21825 Click image for larger version.
    The paint job
ID:	21841 Click image for larger version.
ID:	21849 Click image for larger version.
ID:	21857 Click image for larger version.
  5. Remove Advertisements
  6. #4
    More paint job shots
ID:	21873 Click image for larger version.
ID:	21881 Click image for larger version.
ID:	21889 Click image for larger version.
  7. #5
    The end result and finish!!
ID:	21905 Click image for larger version.
ID:	21913 Click image for larger version.
ID:	21921 Click image for larger version.
  8. #6
    VDubber deejay's Avatar
    Sep 2009
    Canada, Newfoundland
    27
    69
    Looks amazing! Now that its rebuilt you can sell it to me
    2001 Golf 1.8T..
    German's make some good rice.
  9. #7
    Quote Originally Posted by deejay View Post
    Thanks for the comment. It's actually for sale at the moment so if you're serious make an offer.
  10. #8
    Just a few updates.
    Had my custom airbrushed engine cover installed after sitting in the shed for quite some time and also nabbed an Audi 4 rings emblem and fitted it onto my Rieger front bumper mesh grille in the lower front center.
ID:	22225 Click image for larger version.
  11. #9
    So this is basically a list of things that have been done and added to the car over the past 12 months:
    • Fully rebuilt suspension including OEM ball joints, tie-rods, driveshafts, front and rear wheel bearings & hubs.
    • New Koni FSD Shocks with new Neuspeed Sport Springs 38 mm lowering
    • Polyurethane front and rear control arm bushings
    • VF-Engineering polyurethane motor & transmission mounts set and VF-Engineering front sway bar links with polyurethane bushings
    • Upper C-pillar aluminum stabilizer bar
    • Brembo Italy High Carbon Steel and Cadmium plated crossed drilled disc brake rotors front and rear with Bosch Quietcast brake pads
    • European RSR-style rear tail lights
    • E-Code .:R32 style Angel Eye Projector Beam Headlights
    • OEM European headlight switch with functional rear left fog light
    • 18 inch Knig Unknown wheels with 225/40/18 Falken Ziex Tires
    • Rieger Tuning European front bumper, side skirts and rear bumper valance (full body kit) fitted and fully sprayed with PPG Metallic Black Pearl base coat and House of Kolor Kandy Apple Red (UK-11) over base coat for mystical color changing effects and finished with 4 hands of PPG clear coat for an ultimate shine
    • Custom airbrushed Ferrari red flaming engine cover
    • Optional GIAC performance ECU Flash software for stock cams +10 HP/ +15 Ft.lbs
    • 5 speed manual transmission (3.389 final drive ratio) with Stage II street performance clutch and pressure plate upgrade
    • OEM VW Shark fin antenna with built-in antenna amplifier
    • OEM VW matte black rear hatch emblem
    • Red/ Chrome .:R front bumper grille badge
    • OEM Audi Q5 4 rings front grille emblem
    • GTI logo leather steering wheel emblem
    • OEM GTI logo monster rubber floor mats
    • OEM European GTI 25th Anniversary Edition door sill protector foils
    • OEM European GTI 25th Anniversary Edition aluminum sport pedals and footrest
    • OEM .:R32 chrome hatch and hood struts
    • JOM Style Wolfsburg Edition chrome door lock pins
    Yeah I basically burnt through quite some cash just to get the car where it is at today.
    Nonetheless I don't regret doing it as it stands out and is one of a kind, well at least around here where I am from.
  12. #10
    Just starting my MK4 12v VR6 rebuild after a timing chain guide snapped and bent my valves :/ Good excuse to do a complete rebuild and do a few mods here and there. The old engine is getting IE performance parts, a turbo, and 400whp. Yipee!
    Sent from my VS987 using Tapatalk
  1. The Tech Guy's Mk4 Build Thread
    By TheTechGuy in forum MKIV GTI
    Last Post: 05-11-2014, 04:16 PM
  2. Cruzer's MK4 Build Thread 1.8T And Maintenance
    By cruzer076 in forum GTI Owner's Rides
    Last Post: 12-19-2013, 02:03 PM
  3. Mishu's MK4 GTI Build Thread!
    By Mishu in forum GTI Owner's Rides
    Last Post: 11-15-2011, 07:03 PM
  4. Timeline for getting downpipe.
    By ghahn in forum MKVI GTI
    Last Post: 05-03-2011, 12:03 AM
  5. photos, its getting better!
    By killaforniaxkrystina in forum MKIII GTI
    Last Post: 01-17-2010, 02:35 PM
