Spark plugs caked in what seems to be oil.
+ Reply to Thread
Results 1 to 7 of 7
Thread: Spark plugs caked in what seems to be oil.
    Default Spark plugs caked in what seems to be oil.
    So I did a tune up today. Replaced spark plugs and coils with all OEM parts. I noticed the spark plugs I was removing was caked in what seemed to be oil. But when I smelt the oil it smelt nothing like motor oil. Any ideas? I have a VTA catch can by BSH installed. Maybe some blow by is finding its way back into the valve cover via the valve cover ventilation hose connected to my catch can. Here is a picture of a spark plug.
    GTI Master Coltello's Avatar
    Aug 2011
    Upstate, NY
    30
    2,216
    Default Re: Spark plugs caked in what seems to be oil.
    "When can we stop pretending that being color blind is not some form of retardation?"
    I once saw someone say.........What's the business?
    http://myfastgti.com/volkswagen/thre...V-Build-Thread
    The only place you can get some ASS without your girlfriend getting mad...
    http://www.albanyspeedshop.com/
    Default
    Lmao. Nice catch. Smelled*. Don't know why I said "smelt"
  5. #4
    Aug 2011
    Upstate, NY
    30
    2,216
    Quote Originally Posted by IanCAck View Post
    Sorry I couldn't be of more help but I thought that was funny. I've seen oil like when a PCV backs up where oil comes out of the filler neck and dribbles down the coil packs into the plugs. How long ago did you install the cc?
  6. #5
    Jul 2010
    Greater Green Bay, Wisco USA
    2,639
    Inspect the insides of your plug holes. If there is oil looking residue on the walls leading down to the plugs, or if your socket comes out kind of gooey, you need a valve cover gasket. $20 45 minutes to install. Easy as pie.
    2002 VW GTi 337
    Build Thread - 193whp / 227wtq
  7. #6
    Default
    Quote Originally Posted by Coltello View Post
    It's cool. I installed the CC a little over a year ago
  8. #7
    Aug 2011
    Upstate, NY
    30
    2,216
    Yeah so it's not that.
+ Reply to Thread
  1. I need Spark Plugs
    By andahawk in forum MKV GTI
    Last Post: 04-25-2011, 09:33 PM
  2. Spark Plugs
    By LannieDuncan3 in forum MKV GTI
    Last Post: 02-20-2011, 06:02 PM
  3. what spark plugs should i use?
    By FER86GTI in forum MKII GTI
    Last Post: 05-20-2010, 02:47 PM
  4. spark plugs???
    By dz28adams in forum MKIV GTI
    Last Post: 04-30-2008, 09:05 PM
  5. What other Spark plugs
    By imported_MEL in forum MKIII GTI
    Last Post: 08-16-2007, 02:09 PM
