offset?
+ Reply to Thread
Results 1 to 7 of 7
Thread: offset?
    Default offset?
    will a 17 inch wheel with a 50mm offset fit right on my 03 gti or will i need spacers. car is on stock suspension if that helps
    Jul 2010
    Greater Green Bay, Wisco USA
    2,639
    Default Re: offset?
    Need width of your new wheels.
    http://www.willtheyfit.com/index.php...&Submit=Submit
    should help
    2002 VW GTi 337
    Build Thread - 193whp / 227wtq
    Jul 2010
    2,639
    Default Re: offset?
    Better yet:
    http://www.rimsntires.com/specs.jsp
    VWVortex should list OEM size and offset for your current wheels. Compare to the wheels you'd like to get and see how close you can match them. Bam, you win.
    2002 VW GTi 337
  5. #4
    Default Re: offset?
    went with some kosei wheels with yokahama tires, got a really good deal....car will soon look like this
  6. #5
    VDubber
    Aug 2012
    Oak Harbor, Wa
    30
    Default Re: offset?
    From what ive seen, OEM wheels range in offset from +42 to +38. usually the stock 17in and 18in oem wheels run a +38 offset. Now when i installed my coilovers, I ran into my wheel rubbing my coil on a 17x7.5 +38 offest. Now i dont know what suspension you are running. I know your looking at an after market wheel so it all depends on how wide they are as well as offset. Im thinking you will need to run some kind of spacers.
  7. #6
    Jul 2010
    2,639
    Default Re: offset?
    Quote Originally Posted by mk4kdub View Post
    Are you lowered? My 337's BBS RC's are 18x7.5 Et.38 and are fine on the sport suspension. I have a bit of room from coils to rubber.
    2002 VW GTi 337
  8. #7
    Default Re: offset?
    for now i am running on stock suspension, but almost to a promotion at work so hopefully the car budget will grow a little. Plan to just run ultimos for a while and eventually invest in fk's. I went with 25mm spacers for now but i may have to decrease that when i go low.
+ Reply to Thread
  1. Offset??
    By O7GTI in forum MKV GTI
    Last Post: 01-18-2013, 03:59 AM
  2. Replies: 18
    Last Post: 06-24-2011, 08:49 PM
  3. How much offset......
    By Jaydub in forum MKIV GTI
    Last Post: 05-15-2011, 04:38 PM
  4. offset, staggered
    By gtiAnxiety in forum MKV GTI
    Last Post: 01-03-2011, 07:35 AM
  5. Need offset advice!!
    By 03-Jedi in forum MKIV GTI
    Last Post: 03-21-2010, 12:03 AM
