cuts out in boost
+ Reply to Thread
Results 1 to 11 of 11
Thread: cuts out in boost
    Dubber In Training
    Feb 2013
    Butler, KY
    32
    5
    Default cuts out in boost
    Trying to rescue this poor gti.The car runs great, drivin like grandma. Sonn as it hits boost it cuts out and falls on its face. Feels like a bad misfire but i scanned it witha solus scanner no misfire codes. I just got this car from my brother who gave up on it,so i don't know much about it. it has a 3" downpipe,forge 007,and a tune.He put in new coilpacks plugs and injectors from ECS tuning,still have same problem.Any help would be awsome,sorry i don't have more info.
    Dubster Crozarius's Avatar
    Sep 2011
    Austin, Texas
    208
    Default Re: cuts out in boost
    I'm gona guess boost leak since you said it just cuts out. Have you checked the Diverter valve? Maybe it's busted.
    Good luck, and I hope you figure out your issue.
    2011 Candy White DSG MK6
    Unitronic Stage 1+||Injen Intake||Rear De-badge||Red Footwell Lights
    My Build Thread
    VDubber
    Feb 2013
    Autobahn A8
    41
    Doesn't throw any codes? Hmm, could be bad gas, clogged fuel filter??
    Sounds like you need to make to the dealer.. Keep us posted
  5. #4
    Dubber In Training
    Feb 2013
    Butler, KY
    32
    5
    No misfire codes but (g70) maf signal low p0102,p1103,p1116.It needs a hood, headlights and front bumper so i can't really take it to the dealer.i work at a bodyshop so it will be straight soon,just have to get runnin right first.It feels like a misfire,bucks and pops kinda smells rich.someone said the turbo intake tube could be collapsing.If you accel slow through the (miss) it will hold 10lbs but doesnt feel healthy.I can only drive it around our shop so its hard to narrow it down.Thanks ya'll so much for your help.
  6. #5
    Sep 2011
    Austin, Texas
    208
    Maybe you already know, but here is what the codes mean:
    HTH
    My Build Thread
  7. #6
    Dubber In Training
    Feb 2013
    Butler, KY
    32
    5
    Yeah,thats what the solus scanner said.Any info is good th ough thanks.I just found the empty boxes from the injectors,plugs and coilpacks.Are Ngk laser platinum plugs from ecs pre gapped? I'm sure he didn't gap them.The breather hose is completly rotten too.He says the 007 splitter is messed up also.
  8. #7
    Sep 2011
    Austin, Texas
    208
    They should be, but it never hurts to check.
    I just googled what the 007 splitter was. Given that that is messed up, I bet it's your problem. Seems to add up to me any ways. Boosts great until 10lb, then craps out and runs bad. I would assume your tune is stage 2 with the 3" down pipe. I'm not sure how much boost pressure a mk4 holds, but I would assume it's around 20 psi.
    I'd look up how to clean it, fix it, replace it, whatever before I worked on anything else.
    My Build Thread
  9. #8
    VDubber
    Aug 2012
    Oak Harbor, Wa
    30
    Im almost 100% sure that you have a bad n75 valve. 99/100 times that is the cause of boost issues.
  10. #9
    GTI Master Coltello's Avatar
    Aug 2011
    Upstate, NY
    30
    2,212
    Quote Originally Posted by pntrtony View Post
    Pull them out and gap them to .32 if you have no tune. .30 if you're stage 2.
    "When can we stop pretending that being color blind is not some form of retardation?"
    I once saw someone say.........What's the business?
    http://myfastgti.com/volkswagen/thre...V-Build-Thread
    The only place you can get some ASS without your girlfriend getting mad...
    http://www.albanyspeedshop.com/
  11. #10
    VDubber cr_mkiv62's Avatar
    Jul 2011
    Macomb, MI
    74
    boost leak
  12. #11
    Dubber In Training
    Feb 2013
    Butler, KY
    32
    5
    It has a tune,we don't know what kind though.I know the forge splitter is bad he has ruined it messing with it,but seems to work just too loose.I think it would boost fine aside from the bad splitter dv and any leaks.Under a load or when boost starts it seems to misfire,the faster you push the pedal the worse it gets.If ya kinda ease into it its not sa bad but still terrible and if you stay with it it kinda evens out,but will only hold 10 lbs due to the bad dv i assume.It used to hit 20 and fall to 18,19ish. Im sure our scanner at work isnt the best but it should pick up a misfire i would think,its pretty nice. Thanks for all the info i need all i can get.
+ Reply to Thread
  1. Loving the MkV but not the Fuel Cuts
    By BigAl in forum MKV GTI
    Last Post: 09-22-2012, 01:31 PM
  2. Replies: 5
    Last Post: 04-10-2012, 03:22 PM
  3. Installed New South boost gauge.. possible boost leak?
    By draggingframe in forum MKIV GTI
    Last Post: 08-30-2011, 12:22 AM
  4. Replies: 2
    Last Post: 04-30-2011, 01:07 AM
  5. Fuel cuts?
    By GTI_Dan in forum VW GTI
    Last Post: 02-28-2011, 04:26 AM
