Brake booster hose
Results 1 to 3 of 3
Thread: Brake booster hose
    VDubber
    May 2012
    Florida
    71
    Default Brake booster hose
    Replaced old cracked oem brake booster hose to a rubber hose to avoid cracking and after a couple of days the rubber house looks kinked and squished together looks like no air going trew but brakes still work should I keep or go with oem? Thanks
    Default Re: Brake booster hose
    If the hose is collapsing you have a problem.
    Aftermarket hoses, are generally ok, if they are designed specifically for the car, used where they were designed to be used.
    You def' cannot, just use any old "rubber hose" for a brake line.
    OEM or specific replacement hose from a reputable manufacturer only.
    VDubber
    May 2012
    Florida
    71
    Ok thanks man
  1. DIY MKIV GTI/GLI 1.8T PCV Delete/Catch Can Install & Brake Booster Mod
    By Teh Chr!s in forum VW GTI INSTALLS / DIYS ONLY
    Last Post: 06-28-2015, 01:09 PM
  2. Quality Octane Booster
    By White_11GTI in forum MKVI GTI
    Last Post: 03-22-2011, 10:42 AM
  3. Sprint Booster Power Converter?
    By isnibob in forum MKV GTI
    Last Post: 04-28-2010, 11:22 PM
  4. sprint booster?
    By 337lover in forum MKIV GTI
    Last Post: 12-18-2009, 10:50 AM
  5. Brake Booster
    By Fast Freddie in forum MKV GTI
    Last Post: 12-12-2007, 10:00 PM
