Mates, I got a HEX + CAN from bought from Ross Tech months.* I would like to enquire how I can do adaptation for fix my current front left window problem of my 2006 VW Gti V (4 doors).
I don't know what it is caused but the current problem is:
The front left window (right hand drive), i.e. passenger side - the window moves in the opposite direction, i.e. the window opens / moves down when I pull the switch, while the window closes / moves up when I push the switch.* The happens to the passenger side window switch and also the switch at the driver side for that passenger window.* I have done some output test with my HEX + CAN for the front left door and don't know if this would cause such malfunction.
The other switches are all ok, i.e. work properly with the windows moving in the right direction.
Moreover, don't know what I have touched in the VCDS, now the front left passenger window, on top of the problem I described above, cannot be fully closed, i.e. leaving about one inch from the window frame.
I have tried to do adaptation by selecting 52 Door elect, Passenger control module, but he adaptation box is grey and not available for check.*I guess such adaptation require log-in with the security access.* Anyone knows where and how I can get the correct security access code for doing such adaptation. Or to be specific, how I could make use of my HEX + CAN and the VCDS program to get the window malfunction corrected? Or other solutions you could advise?
Many thanks in advance
