07 GTI, Just bought - Idle Rough and Check Engine Codes
Results 1 to 5 of 5
Thread: 07 GTI, Just bought - Idle Rough and Check Engine Codes
    Dubber In Training
    Jul 2011
    5
    Default 07 GTI, Just bought - Idle Rough and Check Engine Codes
    I have an 07 GTI 6 speed. The idle is been hunting while idle. It goes from 1k and goes up slowly to 2k and drops back down to 1.
    A check engine light came on and these are the codes:
    P0507 - Idle air control system. RPM higher than expected
    P0300- Random multiple misfire
    P0301 - Cylinder 1 2 3 4 misfire
    P0171- Bank 1 system too lean
    This car is completely stock. What does this problem sound like?
    Thank you in advance.
    Dubber In Training
    Jul 2011
    5
    Default Re: 07 GTI, Just bought - Idle Rough and Check Engine Codes
    Did troubleshooting on the PCV valve.
    Here are the results:
    I think I did this right. I blew into the part that is disconnected. It felt like no resistance at all and the air was just passing through.
    Here is a pic of the PCV. It looks like oil saturated the outside of it
    Also, I noticed on top of the HPFP it looks cracked. Is this a cause for concern and in order to fix it would I have to replace the entire pump?
    Would the failed PCV valve cause the issues I am having? What is the best and most cost effective way to resolve this issue?
    Thank you
    GTI Master Vlad_I's Avatar
    Jul 2010
    Toronto, Canada
    28
    763
    16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
    Possible Causes
    Mass Air Flow Sensor (G70) defective
    Intake System Leak(s)
    Possible Solutions
    Check Mass Air Flow Sensor (G70)
    Check Fuel Pressure Regulation
    Check Fuel Pump
    Check Injectors
    Check Intake System for Leaks
    Check Exhaust System for Leaks
    Check Secondary Air System for Leaks
    Check Vacuum Pipes for Leaks
    16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
    Possible Causes
    Air Intake System leaking
    Fuel Supply faulty
    Injector(s) faulty
    Ignition Cable(s) and/or Spark Plug(s) faulty
    Ignition Coil(s) faulty
    Exhaust Gas Recirculation (EGR) Valve (N1 stuck/open
    Camshaft Position Sensor (G40) faulty
    Possible Solutions
    Check Misfire Recognition
    Check Air Intake System
    Check Fuel Supply
    Check Injector(s) and Injector Sealing
    Check Ignition Cable(s) and Spark Plug(s)
    Check Ignition Coil(s)
    Check Exhaust Gas Recirculation (EGR) Valve (N1
    Check Camshaft Position Sensor (G40)
    16685/P0301/000769 - Cylinder 1 Misfire Detected
    Possible Causes
    Ignition system
    Fuel injectors
    Fuel pressure
    Running out of fuel
    EVAP canister purge valve
    Evaporative emission system
    Low compression
    Base engine problems
    Controle Module damaged
    16891/P0507/001287 - Idle Control System RPM: Higher than Expected.
    Possible Symptoms
    Malfunction Indicator Lamp (MIL) active
    Possible Causes
    Throttle Valve Control Module (J33 dirty/faulty
    Wiring/Connector(s) from/to Throttle Valve Control Module (J33
    Vacuum Leak
    Possible Solutions
    Check Throttle Valve Control Module (J33
    Check Wiring/Connector(s) from/to Throttle Valve Control Module (J33
    - '07 MKV GTi Coupe BMP
    MKV Guide: Hidden Content
    My build thread: Hidden Content
  5. Remove Advertisements
  6. #4
    Jul 2010
    Toronto, Canada
    28
    763
    I would do this:
    1. Replace coil packs and spark plugs
    2. Get rid of the PCV and get 42DD's catch-can.
    3. Check for vacuum leaks and intake leaks.
    4. Clean the MAF.
    5. Pull the HPFP and check the follower.
  7. #5
    VDubber Kawiman6565's Avatar
    Feb 2011
    So. NH
    24
    98
    Had 2 of the same symptoms with my 07, used MAF cleaner and fixed the P0171 and I also had rpm higher than expected and I had to replace the vacuum regulator and PCV valve
  1. Replies: 0
    Last Post: 07-10-2011, 02:14 PM
  2. 01 gti vr6 rough idle
    By EuroFraidVRT in forum MKIV GTI
    Last Post: 12-10-2010, 05:00 PM
  3. clicking noise from engine idle?
    By zeppler in forum MKV GTI
    Last Post: 06-11-2009, 07:47 PM
  4. Kinda bought an 07, still need credit check
    By dalpod74 in forum Shopping for a New or Used GTI
    Last Post: 10-08-2007, 10:37 PM
  5. rough idle/engine light
    By Scarlet in forum VW GTI Problems / Complaints
    Last Post: 09-12-2007, 06:22 PM
