GTI Dash light problem-HELP
Results 1 to 2 of 2
Thread: GTI Dash light problem-HELP
    Dubber In Training
    Mar 2011
    Elizabethton, Tennessee, United States
    47
    7
    Default GTI Dash light problem-HELP
    I have a strange problem. When I turn on my headlights or just parking lights (with the dash lights on) my volt meter, clock and oil temp gages stop working. If you turn the dashlights off, then everything goes back to normal. I have had the dash apart and checked everything and cannot find out why this is happening.
    I do have a dashlight bulb that is burned out. So just the one over my tach is working. Could this be what is causing this.
    Please help.
    Thanks
    Scott
    Default
    Sounds to me like one of your wires are in the wrong spot...check the switch itself and make sure all interior lights have a gray wire with a blue Tracy to them.... Not the dome and door pin/ switch that should be black with a red tracer or brown with a red....
  1. Mk3 vr6 airbag light problem?
    By eaGTI in forum MKIII GTI
    Last Post: 05-31-2011, 03:59 PM
  2. Parking light and low beam problem
    By Ngcomplete in forum MKVI GTI
    Last Post: 03-28-2011, 08:57 PM
  3. Dash Light
    By firsttimevdub in forum MKIV GTI
    Last Post: 02-18-2011, 10:59 AM
  4. EPC dash light- strange engine problem now.
    By Brennan Kilpatrick in forum ELECTRONICS
    Last Post: 01-20-2011, 09:11 AM
  5. POWER STEERING SERVICE LIGHT AND ESP OFF LIGHT...
    By SUTUKH19 in forum VW GTI Problems / Complaints
    Last Post: 12-07-2007, 07:57 AM
