help me my car is shaking in 4th gear!!!!
Results 1 to 11 of 11
Thread: help me my car is shaking in 4th gear!!!!
    Dubber In Training sobeones's Avatar
    Feb 2011
    5
    Default help me my car is shaking in 4th gear!!!!
    today my car started doing something weird. as soon as i got in about 3200 rpm in 3rd it starts vibrating alot then when i shifted to 4th, 5th, and 6th its a really rough drive. can anyone help me on finding a solution. plz. thanks. i never over rev i always shift at 3000 rpms idk what it could be.
    Red 2004 GTI VR6
    Jul 2010
    Greater Green Bay, Wisco USA
    2,641
    Default Re: help me my car is shaking in 4th gear!!!!
    Need more detials. Is it the engine that is shaking and misfiring? Throwing a check engine light? How about mods of any kind?
    2002 VW GTi 337
    Hidden Content
    Hidden Content - 193whp / 227wtq
    Nov 2007
    8 1 4
    8,221
    Default
    I'm guessing a wheel/tire issue. Are you in a snowy environment?
    Hidden Content Originally Posted by csmith1957
    Bang bang tang!!
  5. Remove Advertisements
  6. #4
    VDubber Kawiman6565's Avatar
    Feb 2011
    So. NH
    24
    98
    Is it only shaking at higher speeds or just in those gears?
  7. #5
    Dubster Miguelito's MkIV's Avatar
    Aug 2010
    Denver, Co
    130
    Possible Cv axle problem?
    does it vibrate ALOT when trying to gain faster?
    if so the cv is shot.
  8. #6
    Jedi Dubber Black_Bunny's Avatar
    Jan 2011
    huntington beach, CA
    313
    its probably not the gear but the speed ur at could be....cv joint, possibly just a wheel balance issue too, non-hub centric wheels, flat spot on tires. motor mounts
    "some say he comes around easter time to give you pretty little eggs"
    "others say he likes eating carrots"
    "all we know is hes called the Black_Bunny"
  9. #7
    Jedi Dubber LeftLaneDriver93's Avatar
    Oct 2010
    Chattanooga, TN
    264
    limp mode?
    2002 Reflex Silver GTi VR6-totaled
    2006 Candy White GTi - 2 door - 6 speed - 35% tint
  10. #8
    Nov 2007
    8 1 4
    8,221
    Quote Originally Posted by LeftLaneDriver93 View Post
    limp mode?
    I doubt it, I am thinking either unbalanced wheel, or a tire that is about to throw a belt. Or, snow and ice jammed up in wheel throwing it off balance.
    Bang bang tang!!
  11. #9
    Dec 2007
    Marietta/Hiawassee Ga
    8,969
    cv joint
    Need something Fabricated? PM me
    Hidden Content
    Hidden Content
  12. #10
    Feb 2011
    5
    i found the problem thank god i could have wrecked. it was a huge bubble in my driver side front tire.
    Red 2004 GTI VR6
  13. #11
    Nov 2007
    8 1 4
    8,221
    Default
    Quote Originally Posted by sobeones View Post
    Glad you found it, I figured it was a tire issue, or wheel unbalanced.
    Bang bang tang!!
  1. not going into first gear
    By Andre Rodriguez in forum 2.0T FSI / TSI Engines
    Last Post: 04-09-2014, 10:20 PM
  2. GTI Shaking motor mount?
    By jhawk in forum MKIV GTI
    Last Post: 11-18-2010, 12:29 PM
  3. HELP! Flutter/Shaking
    By candywhiteko in forum MKV GTI
    Last Post: 10-11-2009, 10:38 PM
  4. Weird Shaking at Moderate Speeds
    By CMAK in forum MKV GTI
    Last Post: 11-26-2008, 08:06 PM
  5. Shaking after swapping tires
    By Tornado_Red_MKV in forum VW GTI SUSPENSION
    Last Post: 05-02-2008, 09:07 PM
