Go Back   VOLKSWAGEN GTI Forum | VW GTI Forum • VW GOLF MKVI GTI Forum • MKV GTI FORUM • MKIV GTI FORUM • MKIII GTI FORUM • MKII GTI FORUM • MKI GTI FORUM > VW GTI Boards > VW MKIV GTI Forum
Reply
Thread Tools Display Modes
Old 08-05-2007, 05:24 PM   #1
consiglio.anthony
Dubber In Training
consiglio.anthony's Avatar
Default Transmission Questions
Just put new tranny on, but the speedometer doesn't work anymore? Its plugged in though the tach works. What did I mess up, second question does anyone know what size o-rings go on the slave cylinder line? I have lost mine, but I have one that works for the time being, nevertheless I need to get some o-rings. \
Also
The Stealership Guy told me I only need 2 quarts of trans gear oil, but the bently manual says otherwise whats the correct amount anyone?
consiglio.anthony is offline   Reply With Quote
Old 01-14-2008, 07:19 AM   #2
justn868
DubMeister
justn868's Avatar
Send a message via AIM to justn868
Default Re: Transmission Questions
did you do the swap yourself?
__________________
Black 2002 GTI 1.8T with many goodies...
If you drop the clay
Throw it it away
justn868 is offline   Reply With Quote
Old 01-14-2008, 04:09 PM   #3
boostedJTi
REVIEW STAFF
boostedJTi's Avatar
Send a message via AIM to boostedJTi Send a message via MSN to boostedJTi
Speed sensor is the reason speedo won't work, make sure you have a working one. Follow bently book, manuals seem to be right
boostedJTi is online now   Reply With Quote
Reply
Tags: ,
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Shift knob removal/swap Manual transmission 07gtiMkV OTHER MKV GTI ACCESSORIES 13 06-25-2010 03:41 PM
issue/problem with DSG transmission joel.c VW GTI MKV Forum 27 04-18-2009 09:48 AM
Done breaking in engine, just plain broke the transmission imported_incubowski VW GTI MKV Problems / Complaints 15 08-11-2008 06:37 PM
Transmission Change imported_I Eat Babies VW GTI POWERTRAIN 1 08-06-2007 09:54 PM
Auto-Shift transmission? tehmarken VW GTI MKV Features 29 03-29-2007 11:49 PM
Design By: Miner Skinz.com
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
Ad Management by RedTyger
Volkswagen Forum Volkswagen Jetta Volkswagen Tiguan Portland Oregon New & Used Cars small towns Volkswagen Passat Las Vegas Myths privacy policy
