Go Back   VOLKSWAGEN GTI Forum | VW GTI Forum • VW GOLF MKVI GTI Forum • MKV GTI FORUM • MKIV GTI FORUM • MKIII GTI FORUM • MKII GTI FORUM • MKI GTI FORUM > VW GTI Boards > VW MKIV GTI Forum
Reply
Thread Tools Display Modes
Old 10-26-2008, 05:22 PM   #1
rockmkivgti
Dubster
rockmkivgti's Avatar
Default full throttle problem
ok guys i need help. i have a problem when i am driving. my fuel seems to cut in sperts. at full throttle im not getting the response that i was when i first got my chip. if i let off the gas slightly..i mean hardly noticeable, it starts to add more fuel and feels right..meaning it acts right. i dont know i have tried a lot of stuff...maybe its the coil packs..and today when i hit hard it cut out bad like my spark plugs or something f*cked up..someone please help me.
__________________
back to stock clutch, new tranny, Neuspeed lowering springs, borla catback exhaust with cap for open DOWNPIPE, ECS N75, EIP short shifter, stubby antenna, smoked front and side marker lights, matching eyelids, new tailights,euro headlight switch... custom painted engine cover. forge 004 blow off valve, new south boost gauge, 17inch Rial Nogaros 2 inch lip 235/40/17 HTZ+sumitomos,unitronic stage II+ chip 23 psi.
rockmkivgti is offline   Reply With Quote
Old 10-26-2008, 05:51 PM   #2
El Brando
Jedi Dubber
El Brando's Avatar
Default Re: full throttle problem
Any CEL? Ive heard some MKVs have a TSB or recall on the fuel pressure sensor. If you are getting an intermintent CEL, I think thats more indicitive of coil packs, but you should get the codes read regardless. VAG-COM is best but you can also go to most auto parts stores and theyll read the code for free. You write down the code or codes, then google search them or search them on vwvortex. Good luck! Keep us posted too.
I didnt see you have a MKIV till after I posted, but maybe it could still help!
El Brando is offline   Reply With Quote
Old 10-26-2008, 06:02 PM   #3
rockmkivgti
Dubster
i have no cel's and i have been blowing some coils.. but it isnt miss firing right now but under load it seems like it could be missing under load.
__________________
Old 10-26-2008, 08:19 PM   #4
CMAK
GTI Master
CMAK's Avatar
gotta love vw electrical ey about as good as the service imao
CMAK is offline   Reply With Quote
Old 10-26-2008, 09:30 PM   #5
volcano
GTI Master
volcano's Avatar
could be your TP sensor has a short at WOT.
volcano is online now   Reply With Quote
Old 10-26-2008, 10:28 PM   #6
rockmkivgti
Dubster
tp sorry not sure bout wat that is
im thinking throttle positioning sensor... i dont know because when i hold it down sometimes it starts acting like maybe its fuel filter because of how it acts. picks up the flattens out picks up flattens out..im stumped
__________________
Last edited by rockmkivgti; 10-26-2008 at 10:34 PM.. Reason: thought bout the acronym..
Old 10-26-2008, 10:37 PM   #7
Jyden
Jedi Dubber
Jyden's Avatar
Honestly, get it vagged. Whether or not there's a CEL, it'll still read what's going on in the car and that may point you at least in some direction.
__________________
Sweet baby Jesus...
Jyden is offline   Reply With Quote
Old 10-26-2008, 11:40 PM   #8
southernGTI
VDubber
southernGTI's Avatar
Send a message via AIM to southernGTI Send a message via Yahoo to southernGTI
I would get it scaned for sure. Being that it is throttle variant, it may be the TPS (throttle postioning sensor) or the sensor on the pedal its self its acting up. Scan tool should show you whats going on
__________________
08 GTI-daily driver, so stock its boring.....
94 rx7- 13b half-bridge single
78 Z28-blown 355
04 CBR 600RR- stretched and lowered
southernGTI is offline   Reply With Quote
Old 10-27-2008, 05:40 PM   #9
rockmkivgti
Dubster
yeah i changed spark plugs to the iridium ngk's today..slight difference. still something is wrong..
__________________
Old 10-28-2008, 06:27 PM   #10
rockmkivgti
Dubster
ok everyone..i have figured out the problem. it should have been done before anything. the throttle body was filthy. so i cleaned it out with cleaner and it is like a bullet now..hooray for me!!!! thanks guys!! so if anyone experiences slight hesitation and feels like they cant figure it out...try cleaning everything in the intake system, because obviously oil is in the system and it gets to the intercooler and then in turn gets to the throttle body. so i think thats right..lol
__________________
Old 10-28-2008, 06:49 PM   #11
southernGTI
VDubber
sounds good. You can look for BG products at a local dealership or mechainc shop and have the fuel injection service done. It will clean the intake, valves, throttle body, etc from oil and dirt deposites. works very well. I must run 3-4 a day and the results are always good. Also known as a 3-step. BG is the best one out there IMO
__________________
78 Z28-blown 355
Reply
Tags: , , , ,
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Throttle Body Pipe - DIY prpltrck VW GTI POWERTRAIN 6 02-19-2010 02:11 PM
Shimmy on throttle Rusty_Cage VW MKIV GTI Forum 16 03-03-2008 09:31 PM
Throttle Steering KGDeAng PERFORMANCE DRIVING 3 03-04-2007 09:00 AM
Full throttle high pitch noise GTI MKV VW GTI MKV Problems / Complaints 9 12-25-2006 07:13 PM
Design By: Miner Skinz.com
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
Ad Management by RedTyger
Volkswagen Forum Volkswagen Jetta Volkswagen Tiguan Portland Oregon New & Used Cars small towns Volkswagen Passat Las Vegas Myths Things To Do In Portland Oregon Local Search Marketing Agency privacy policy
