Go Back   VOLKSWAGEN GTI Forum | VW GTI Forum • VW GOLF MKVI GTI Forum • MKV GTI FORUM • MKIV GTI FORUM • MKIII GTI FORUM • MKII GTI FORUM • MKI GTI FORUM > VW GTI Boards > VW GTI MKV Forum
Reply
Thread Tools Display Modes
Old 02-03-2008, 06:37 PM   #1
GTI racer
Dubber In Training
GTI racer's Avatar
Default Air Intake HELP
Is there a cold air intake that i can get on my GTI that doesn't require me to remove or trim the stock engine cover?
GTI racer is offline   Reply With Quote
Old 02-03-2008, 06:52 PM   #2
Lil Fussell
Dubster
Lil Fussell's Avatar
Send a message via AIM to Lil Fussell
Default Re: Air Intake HELP
yes the Carbonio Cold Air Intake
http://goapr.com/VW/products/intake_...io_mkvgti.html
__________________
Nothing matters once that turbo spools up
All my cares go away
Lil Fussell is offline   Reply With Quote
Old 02-03-2008, 06:55 PM   #3
GTI racer
Dubber In Training
GTI racer's Avatar
are there any that are connected to a pipe.
Old 02-03-2008, 06:56 PM   #4
SpeeDemon
DubMeister
SpeeDemon's Avatar
Send a message via AIM to SpeeDemon
Make sure if you go with the Carbonio to remove the MAF screen inside the stock cover. It will add a few extra HP...lil trick I've learned from:
http://www.swankmonkey.com/vw/jetta/2006/other_tricks/
__________________
234whp/282ft-lb. Revo Stage II, EVOMS CAI, Milltek Turbo/Cat-back Exhaust, ForgeDV, Air Bypass, NS Hi-Flo Diffuser kit, Forge Intercooler, Eurojet PCV, NewSouth Boost gauge, Dieselgeeks Short shifter, Clubsport suspension, RSD rear stress bar, H&R F&R sway bars, tint, grounds
SpeeDemon is offline   Reply With Quote
Old 02-03-2008, 07:15 PM   #5
GTI racer
Dubber In Training
GTI racer's Avatar
i have herd that is you get the Evoms Intake. you dont have to take off the stock engine cover is that true.
if so were do they sell them.
Old 02-03-2008, 08:12 PM   #6
zeonic
mmm...beer
zeonic's Avatar
false. the pipe is way too big and is right in the way of the engine cover. you can trim the cover to fit. need a table saw or something like that. or if your good with a dremel and have a few hours to kill. i might do that to mine one of thease days.
this is prolly what they were talking about.
http://www.evoms.com/marketplace/Vie...A62E17E6AE4%7D
__________________
zeonic is offline   Reply With Quote
Old 02-03-2008, 09:43 PM   #7
GTI racer
Dubber In Training
GTI racer's Avatar
what is the hp gain with the Carbonio CAI?
Old 02-03-2008, 10:41 PM   #8
TwinTurboBoost
Ban Master Flex
TwinTurboBoost's Avatar
not enough for you to feel, but def. sounds great. It will also make your dv sound louder. I would say you can get like 7 hp with a nice intake.
__________________
Quote:
Originally Posted by slippednfelled View Post
basically dont ever battle with TTB or Dlight, you will not win...... ever. its a rule.
I know its off topic but its great advice.
TwinTurboBoost is offline   Reply With Quote
Old 02-04-2008, 08:58 PM   #9
GTI racer
Dubber In Training
GTI racer's Avatar
does anyone have a picture of there engine with Carbonio Cold Air Intake?
if you do please post.
Old 02-04-2008, 09:32 PM   #10
Dragon
Shaken not stirred...
Dragon's Avatar
Thanks Google! (OK it's on an ATree but its close)
__________________
Dragon is offline   Reply With Quote
Old 02-04-2008, 09:46 PM   #11
D.Light
Brings The Ruckus
D.Light's Avatar
Here's the CAI version from Carbonio
__________________
That Ain't Kool-Aid Up In MY Cup, I stay Sippin That Purple-Oil
D.Light is online now   Reply With Quote
Old 02-04-2008, 09:55 PM   #12
GTI racer
Dubber In Training
GTI racer's Avatar
i found one on the mkv 2.0t
Old 02-05-2008, 07:08 PM   #13
GTI racer
Dubber In Training
GTI racer's Avatar
isnt having the the Carbonio the same as having the stock air box with a K&N drop-in filter
Old 02-05-2008, 07:12 PM   #14
Dragon
Dragon's Avatar
It's pretty close...
However, if I lived in an area that floods on a regular basis, I'd consider it.
__________________
Old 02-05-2008, 07:14 PM   #15
D.Light
Brings The Ruckus
D.Light's Avatar
My streets flood on a reg. basis so I went short ram
__________________
Old 02-05-2008, 07:29 PM   #16
Dragon
Dragon's Avatar
Quote:
Smart.
__________________
Old 02-05-2008, 07:30 PM   #17
D.Light
Brings The Ruckus
D.Light's Avatar
Thank ya kindly sir
__________________
Old 02-05-2008, 07:42 PM   #18
banditscout
Fahrenheit GTI Owner
banditscout's Avatar
The difference in power between a short ram and a full CAI is negligable on our cars...At the velecity that the turbo pulls in outside air, there isn't much time for it to heat up...just my 2 cents.
__________________
GIAC X-Chip, Neuspeed P-Flo SRI, Eurojet PCV Fix, New South Performance Column Mounted Boost Gauge, AS OF TODAY- GIAC DSG REFLASH (AMAZING!!)*
banditscout is offline   Reply With Quote
Old 02-05-2008, 07:45 PM   #19
D.Light
Brings The Ruckus
D.Light's Avatar
Thats what i was thinking, add a heat shield to it and pretty much no heat will get in there
__________________
Old 02-06-2008, 05:42 AM   #20
lumns
GTI Master
lumns's Avatar
Send a message via AIM to lumns
go for the neuspeed and do this
__________________
unitronic chipped, neuspeed intake, resonator removed, H&R racesprings, debadged, 35 & 20% tint. stealth installed valentine one radar detector w/ concealed display and volume control. Tinted Tail Lights and Rear emblem.
Soon to add: Eurojet turboback exhaust
lumns is offline   Reply With Quote
Old 02-06-2008, 06:34 PM   #21
GTI racer
Dubber In Training
GTI racer's Avatar
did u cut you Engine cover?
i want the car to just sound good.
will the K&N drop-in filter make it sound louder?
Old 02-06-2008, 07:42 PM   #22
Fudsey
VDubber
Fudsey's Avatar
I just added a K&N drop filter to mine and it made it a little louder but not a lot. It does add some WHP but how much I couldn't tell you. Probably only a little less than a CAI would. Just have your resonator removed, this will add a better sound to your exhaust. I gotta do this soon.....
See kryptonkid's post http://myfastgti.com/volkswagen/show...lips-3225.html
He's got a link to hear it too on page 2....
__________________
Fudsey is offline   Reply With Quote
Old 02-06-2008, 09:32 PM   #23
lumns
GTI Master
lumns's Avatar
yea i cut my engine cover.
neuspeed p-flo+ resonator delete=sexy sound
__________________
Old 02-06-2008, 09:39 PM   #24
D.Light
Brings The Ruckus
D.Light's Avatar
After I get my short ram slapped on this weekend I'll be takin the ole gti down to an exhaust shop to get the resonator removed, probably monday, I'll try to get a sound clip up for the MKIV guys.
__________________
Reply
Tags:
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Looking to buy an intake for my MKV imported_WaZzAp1101 VW GTI POWERTRAIN 11 09-27-2007 06:17 PM
APR ECU and ABD intake incubus187 VW GTI POWERTRAIN 3 09-26-2007 02:27 PM
best Intake? FreddyGTI VW GTI POWERTRAIN 6 07-23-2006 10:14 PM
Intake blackgti06 VW GTI POWERTRAIN 18 07-23-2006 06:33 PM
Intake blackgti06 VW GTI POWERTRAIN 7 06-04-2006 11:14 PM
Design By: Miner Skinz.com
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
Ad Management by RedTyger
Volkswagen Forum Volkswagen Jetta Volkswagen Tiguan Portland Oregon New & Used Cars small towns Volkswagen Passat Las Vegas Myths Things To Do In Portland Oregon Local Search Marketing Agency privacy policy
